1. AC Question's Avatar
    Someone please help! My Google LG Nexus 5 phone started acting strange about 3-4 weeks ago, turning itself on and off, not charging and battery drain withing minutes?? Keep getting "Unfortunately MobileGo has stopped" message?? Thought the problem was battery, purchased and installed new, problem persists?? Anyone??? Thank You!
    01-23-2017 09:16 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Is the power button sticking?
    01-23-2017 09:19 AM
  3. 1Yellowfrog's Avatar
    Hi, and thank you, power button does not seem to be sticking, and not sure how to clear cache, just for that app, or the entire phone?
    01-23-2017 09:25 AM
  4. Golfdriver97's Avatar
    For the whole device. Here is how: [GUIDE] Nexus 5 Recovery
    I first put that suggestion down, but realized the boot loop issue, and reconsidered that as a solution. You can try, nothing will be lost aside from about 10 minutes if it doesn't work.
    01-23-2017 09:57 AM
  5. 1Yellowfrog's Avatar
    I'll give it a try, thank you so much!
    01-23-2017 10:00 AM
  6. 1Yellowfrog's Avatar
    still getting mobilego has stopped, waiting to see if it will still starts turning on and off by itself
    01-23-2017 10:21 AM
  7. Golfdriver97's Avatar
    Is mobile go an app you downloaded?
    01-23-2017 02:37 PM
  1. Display goes off and on while charging
    By ogdlow in forum Samsung Gear S2
    Last Post: 03-19-2017, 07:13 PM
  2. Unfortunately the process com.android.systemui has stopped
    Last Post: 01-30-2017, 01:35 AM
  3. Replies: 1
    Last Post: 01-23-2017, 09:12 AM
  4. I keep getting Authentification problem
    Last Post: 01-23-2017, 08:19 AM
