A
AC Question
Oh my children's phones I have the settings locked (via app lock) to prevent unwanted to changes to the phone. However I can not figure out a way to have the ability to still connect to a wifi network with out going into the overall settings. Is there a shortcut to put on the home screen, or a separate app that allows you to connect. I would this would be a rather simple task but I have not been able to figure this one out.
Thanks
DCS
Thanks
DCS
