A AC Question Feb 6, 2017 #1 The cord it is plugged in with is good. When I unplug and plug back in it flashes blue, green and then blue about 5 or 6 times and then goes off. It doesn't seem to be paused or sleeping.
srkmagnus Retired Moderator May 23, 2010 13,434 210 0 Visit site Feb 6, 2017 #2 Try different power outlet(s) and see if that helps. If not, then I would suggest contacting Samsung as the device may be defective. Upvote 0 Downvote
pkcable Q&A Team Leader, VR Expert Ambassador Jun 8, 2010 3,583 28 48 Visit site Feb 6, 2017 #3 Have you tried re-positioning the device? Some wireless chargers require precise positioning in order to affect a charge. Upvote 0 Downvote
