1. AC Question's Avatar
    I want to change the default storage memory so when i download any app from play store it will be installed automatically on the sd card .. my mobile is s7 edge (android nougat)
    02-08-2017 09:14 PM
  2. ManiacJoe's Avatar
    It does not work that way. App installs always go to the internal storage.
    Some apps let some of their parts be moved to the SD card, but it is not worth the hassle.
    Your phone may or may not let you format the SD card as an extension of the internal storage. This has pros and cons.
    The SD card is best used for your photos, music, videos, and documents.
    Rukbat likes this.
    02-09-2017 05:12 AM
  1. How to make sd card as my default memory
    By SHANEEJAH in forum Ask a Question
    Last Post: 02-09-2017, 02:55 PM
  2. Alarm mutes during calling state? How to deactivate?
    Last Post: 02-09-2017, 06:11 AM
  3. Replies: 1
    Last Post: 02-09-2017, 05:26 AM
  4. Replies: 1
    Last Post: 02-08-2017, 11:32 PM
  5. New Start-up screen in Beta Version 7.0 on Samsung Galaxy s7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-08-2017, 11:29 PM
