1. AC Question's Avatar
    Hi. I've charged my Samsung A5 2016 full, and used it as usual my activity. After my battery percentage left 40%, suddenly my smartphone was off directly. It happened almost 6 days a go until now.
    And I try to charge my smartphone only until 43%, and it's still 43% until 5hours in normal activity (open social media, editing picture). After that the battery reduce based on the way I used it, not drop like if I was full charged.
    Does anyone could give me some advice about that? Thanks a lot
    02-12-2017 09:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try recalibrating the battery sensor software by charging up to 100%, then using it normally until it shuts off automatically from low battery, then charge back up to 100%. If the problem persists, then the battery might be defective or failing -- contact Samsung if it's still under warranty, or bring it to a repair shop.
    02-12-2017 11:39 PM
  1. Multi OS with my first Android phone
    By horseybob in forum Introductions
    Last Post: 03-02-2017, 02:15 AM
  2. Replies: 1
    Last Post: 02-13-2017, 12:04 AM
  3. Can I transfer my contacts from my old tab3 to my new tab 3?
    Last Post: 02-12-2017, 11:50 PM
  4. LG G5:My music is getting deleted???
    By Awkward Yunyoo in forum LG G5
    Last Post: 02-12-2017, 11:45 PM
