1. AC Question's Avatar
    I noticed my Redmi4 (Android version 6.0.1) came with a pre-installed app.
    It's called Cheetah Mobile Cleanmaster SDK.
    I read some bad reviews of this app here on AC. Should I keep the app? Or disable it and use another one?
    02-14-2017 05:12 AM
  2. Javier P's Avatar
    Welcome to the forums. I'd recommend you to disable it, if that's possible. This kind of app can do more harm than good.
    02-14-2017 05:48 AM
  1. How do disable the read receipts for the S7 with emails?
    By Henry Lee3 in forum Samsung Galaxy S7 edge
    Last Post: 02-14-2017, 01:43 PM
  2. Can I Use The Stylus On The Screen For Drawing?
    By WingLT in forum Lenovo Yoga Book
    Last Post: 02-14-2017, 05:10 AM
  3. Replies: 0
    Last Post: 02-14-2017, 02:37 AM
  4. Can the heads up notification be disabled on the LG V20?
    Last Post: 02-13-2017, 10:28 PM
  5. Replies: 0
    Last Post: 02-13-2017, 05:46 PM
