A AC Question Feb 16, 2017 #1 Swiping does not work for me. I swipe and swipe and eventually lose the Call.
F FWF11 New member Jan 30, 2017 4 0 0 Feb 16, 2017 #2 Guest:You do not mention your brand of phone but,if you had a Samsung S7,as I have,you can use the home button to answer calls. Upvote 0 Downvote
Tim1954 Q&A Team Jan 17, 2016 6,924 1 0 Feb 17, 2017 #3 With Samsung, you can go into settings... Accessibility... Answering and ending calls... OR phone... More... Settings... Answering and ending calls... Upvote 0 Downvote
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,741 11,158 113 Feb 17, 2017 #4 Welcome to Android Central! Which direction are you swiping? Depending on the phone, you might have to swipe up or right. Upvote 0 Downvote
