1. AC Question's Avatar
    I've factory reset my phone, location is off, bluetooth is off, sync is off for everything, all the apps I don't use are disabled yet it's still happening. It randomly started happening all of a sudden. Please help!
    02-17-2017 01:21 PM
  2. jasonandrews25788's Avatar
    maybe this happens because bad battery calibration or damaged battery,however I recommend to re-calibrate your battery.
    02-17-2017 02:52 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you actually seeing worse battery life overall? Did this happen during a period of inactivity, or were you actively using the phone?
    02-17-2017 07:27 PM
  4. danielleyoung's Avatar
    Inactivity. It was during school so it wasn't switched off, just in my bag and I wasn't using it and it drained so badly without WiFi or data on.
    02-19-2017 07:28 AM
  5. B. Diddy's Avatar
    The problem with the Android OS listing is that various apps might be utilizing components of the OS, so it's hard to pinpoint what was the main cause. See if it happens in Safe Mode, which can help narrow things down to something you installed vs something preinstalled.
    Laura Knotek likes this.
    02-19-2017 12:10 PM
  6. guptasachin760's Avatar
    Im facing same problem does anyone have solution what to do?
    03-08-2017 01:41 PM
  1. You will uninstall all your Music Apps After using This App
    By Android Usss in forum Android Apps
    Last Post: 02-27-2017, 06:27 AM
  2. Replies: 3
    Last Post: 02-20-2017, 09:32 AM
  3. Why can't I move apps to my SD card?
    By JFake155 in forum General Help and How To
    Last Post: 02-19-2017, 12:04 PM
  4. Galaxy s7 battery draining out of nowhere
    Last Post: 02-17-2017, 10:16 PM
  5. Replies: 1
    Last Post: 02-17-2017, 12:41 PM
