1. AC Question's Avatar
    I have used smart lock before... But after 2days i don't like to keep it. So i removed it and kept normal pattern lock. so, now it's opening with drawing pattern. Like if i slide up for unlock.. It opens and after some time it is opening directly without drawing a pattern...
    Plzzz help me in this
    I hope you can do it..
    Thank you.
    02-21-2017 06:07 AM
  2. belodion's Avatar
    Does this persist in Safe Mode?
    02-21-2017 06:46 AM
  3. Javier P's Avatar
    Welcome to the forums. What phone do you have? What time have you set under settings - security - automatically lock? Have you restarted your phone after disabling smart lock?
    02-21-2017 07:42 AM
  1. Replies: 1
    Last Post: 02-21-2017, 12:33 PM
  2. I have an At&t GS7 and am in the UK, how do I upgrade!
    By JaiDaHaus in forum Android 7.0 Nougat
    Last Post: 02-21-2017, 05:41 AM
  3. lg pro lite software problems
    By izabdi in forum Ask a Question
    Last Post: 02-21-2017, 02:49 AM
  4. Verizon Moto X on cricket (at&t) - will it have hspa+ access?
    Last Post: 02-21-2017, 02:40 AM
  5. Replies: 0
    Last Post: 02-21-2017, 02:03 AM
