1. AC Question's Avatar
    I was using my phone earlier today and was at 50% battery and about 10 seconds later I got the low battery beep and it was at 5%. When I got home I plugged it in and in the past hour the battery has charged less than 10%. I haven't installed anything new or updated any apps recently. Any ideas what to do?
    02-21-2017 03:00 PM
  2. nahoku's Avatar
    The symptom you describe, high level to low level instantly, points to a bad battery. What device? Does it have a removable battery or is it embedded? Anytime a battery discharges to a very low level, it'll take a longer time to regain charge... this is normal. Leave it charging and it should eventually charge fully. You'll probably see the same thing happen again, so if the battery is embedded, you'll need to have it serviced to have the battery replaced.
    02-21-2017 06:23 PM
  1. Replies: 6
    Last Post: 02-22-2017, 09:29 PM
  2. Replies: 1
    Last Post: 02-21-2017, 08:41 PM
  3. Replies: 0
    Last Post: 02-21-2017, 02:52 PM
  4. Is S Health MAP tracking losing data points
    Last Post: 02-21-2017, 02:34 PM
