1. AC Question's Avatar
    I have had my ICONX for about 6 months now and they worked great until today, when i went to use them the volume on the headphones and the phone was all the way up but the sound was very low, dose anyone have an idea of whats going on or how to fix this ?
    02-22-2017 10:00 PM
  2. martindeporres169's Avatar
    Any idea? i have the same issue.
    03-04-2017 11:05 AM
  3. William Tawes's Avatar
    I am on my second set, and same issue has occurred for me again. First I thought it the firmware update... it's not.... I thwn thought it was the cushions for the earbuds and changed the sizes, removing them altogether helped but not good solution.... resetting to factory didn't help.... someone said online they think the headphones think they are 5.1 and attempting to compensate.... not really sure... when I talked to Samsung they denied this was a problem until I pointed out the fact this has been posted many many times on there own forum... at which point they ended the converstation and said to swap the units...
    I wish I had an answer but I can I have tried just about everything. The headphones are an great concept but Samsung missed the mark...
    Not sure if this will help, but the stride distance is off between 1/2 to 3/4 miles when running on a treadmill or running outdoors... heart rate and calories are pretty accurate.
    Good.luck on the volume, I am hopin Samsung will issue a patch to figure out the problem
    04-04-2017 06:16 PM
  1. Replies: 8
    Last Post: 02-25-2017, 05:58 PM
  2. Gear S3 and custom ringtones?
    By racedog in forum Samsung Gear S3
    Last Post: 02-23-2017, 12:13 AM
  3. Replies: 0
    Last Post: 02-22-2017, 04:40 PM
  4. Replies: 0
  5. Samsung S7: Volume selector stuck
    By DJ_Ben_Lord in forum Ask a Question
    Last Post: 02-22-2017, 01:22 PM
