1. AC Question's Avatar
    Going to Cuba and the resort we are going to charges for wifi.
    We can buy wifi access cards to use and I want to be able to share this access so we only have to buy one card at a time. I would use the built in wifi hotspot on the S7 to do this.
    My problem is, when I go into airplane mode, and turn my wifi back on, the phone will not allow me to open a hotspot to share wifi access.
    I can disable data by disabling data roaming and mobile data but is there a way to also shut off the cellular radio?
    *#*#4636#*#* does not work.
    Any help would be appreciated!
    Jim
    02-24-2017 11:57 AM
  2. kg4icg's Avatar
    You cannot have hotspot or wifi direct on to use wifi from another source, It is either one or the other, not all at the same time
    02-24-2017 12:51 PM
  1. Bluetooth turns off when phone power is off
    Last Post: 03-01-2017, 09:01 AM
  2. Replies: 21
    Last Post: 02-26-2017, 12:08 AM
  3. Tell me how to root lg g5 h860n with nougat?
    By AC Question in forum LG G5
    Last Post: 02-24-2017, 11:54 AM
  4. Replies: 0
    Last Post: 02-24-2017, 11:49 AM
  5. Replies: 1
    Last Post: 02-24-2017, 11:48 AM
