1. AC Question's Avatar
    so i left my lg4 plugged in when i got home last night, and i woke up this morning to it [while still plugged in] refusing to power on or show any sign of receiving a charge. I'm not even getting the 0% screen or anything. Any help would be much appreciated.
    02-26-2017 04:50 PM
  2. Morty2264's Avatar
    Welcome to the forums! Unplug your device and take the battery out, wait ten seconds or so, and then insert it and see if the phone powers on on its own. Keep us posted!
    02-26-2017 04:53 PM
  3. Droidhelpahh's Avatar
    I've tried that a few times, no luck. I also tried cleaning out the charging port as well as holding down the power button for a couple minutes. I switched the battery with the battery from an older model Lg and am having the same problem still. Any other ideas?
    02-26-2017 05:00 PM
  4. Assassin Army's Avatar
    Your phone might be hard bricked or just broken
    02-26-2017 11:43 PM
  5. Morty2264's Avatar
    If you're having the same result with two different batteries, perhaps you should contact LG or go to where you purchased the phone. How old is it? Is it under any type of warranty?
    02-27-2017 07:51 AM
  1. I cannot connect to the internet on my g6
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-27-2017, 04:21 AM
  2. Replies: 1
    Last Post: 02-26-2017, 06:09 PM
  3. I cannot connect to the internet on my g6
    Last Post: 02-26-2017, 04:18 PM
  4. Replies: 0
    Last Post: 02-26-2017, 03:53 PM
  5. Replies: 0
