1. AC Question's Avatar
    Hi, so ive had the Samsung galaxy s7 edge for about 6 months of a 18 month contract, within the first 2-3 months i dropped the phone causing one large crack on the screen. Over the months charging it (i presume the heat) has caused the glass to crack/shatter into tiny pieces which i am living with due to the hefty £350 quotes to fix. However recently the phone stopped charging so i bought a new charger which is a more snug fit but still only charges if it is pushed hard over to the right. I would like some advice on what the best Option is as cancelling my contract so soon would leave me with a huge bill and paying to fix the screen and charger could prove more!
    03-02-2017 11:29 PM
  2. Matty's Avatar
    It unfortunately seems like you have damaged your charging port since it's only charging when "it is pushed hard over to the right.". A short term fix would be to possibly get a wireless charging pad. At least you can still charge and use the phone With regards to the cracked screen. Maybe purchase a screen protector which can over the cracked glass and then you will at least have a smooth surface
    Hope this helps a little!
    03-02-2017 11:37 PM
  1. Galaxy Tab S3 - No 8 inch version this time?
    By AC Question in forum Samsung Galaxy Tab S3
    Last Post: 04-11-2017, 07:35 AM
  2. Google Assistant Update for S7 (where is it?)
    By left4dead in forum Samsung Galaxy S7
    Last Post: 04-08-2017, 05:23 PM
  3. Samsun galaxy s6 odin3 problem Device: 5, Binary: 1
    Last Post: 03-02-2017, 11:26 PM
  4. Samsung Xcover 4 < Active
    By Law2138 in forum Samsung Galaxy S7 Active
    Last Post: 03-02-2017, 11:06 PM
  5. Replies: 1
    Last Post: 03-02-2017, 09:53 PM
