1. AC Question's Avatar
    intermittent no sound on pixel c, reboot fixes the problem
    03-03-2017 12:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.google.com/nexus/answer/2852139?hl=en
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    03-06-2017 12:48 PM
  1. Cloth(day dream esk) case for pixel XL
    By Mark_Twain007 in forum Google Pixel XL Accessories
    Last Post: 03-05-2017, 06:11 AM
  2. No apps to perform this action
    Last Post: 03-03-2017, 04:41 PM
  3. Replies: 1
    Last Post: 03-03-2017, 12:18 PM
