1. AC Question's Avatar
    I have an honor 8 and I use a white noise app to sleep through the night. On my current phone the app keeps pausing itself, sometimes after a few minutes, sometimes after a couple hours but at some point it always paused and then I have to press play again, which wakes me up. I've tried multiple white noise apps and this keeps happening, there's clearly some kind of setting that is causing the audio to go back to pause. Any suggestions?
    03-04-2017 05:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Huawei tends to be pretty aggressive about RAM management, so it might be killing the app automatically. Check the system settings for a battery or memory management section, and if so, look for an option to "protect apps." Make sure your white noise app is "protected" from the system's homicidal rampage.
    03-05-2017 02:31 AM
  1. Replies: 1
    Last Post: 03-05-2017, 02:39 AM
  2. Replies: 1
    Last Post: 03-05-2017, 02:37 AM
  3. How to listen to music on gear s2 ?
    By sNoahs in forum Samsung Gear S2
    Last Post: 03-05-2017, 02:35 AM
  4. Replies: 1
  5. How do you save photos on a android ZTE?
    Last Post: 03-04-2017, 05:06 PM
