1. AC Question's Avatar
    I don't like the new update. I can't find my flashlight on my phone now. I just to could pull my screen down and it would have all of my options to choose from.
    03-06-2017 01:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can't uninstall updates. You might be able to flash the previous firmware using Odin: [Guide][Samsung] How to flash Stock ROM via ODIN with the New Interface
    Is the flashlight issue the only reason, or are there a lot more?
    03-06-2017 03:08 AM
  3. Renata Catalinoiu's Avatar
    Yes indeed, you can downgrade or upgrade your OS with Odin 3 , Kies 3 or smart switch.
    But be aware , installing a custom OS will void warranty and permanently lock your acces to KNOX containers.
    03-06-2017 03:25 AM
  1. How to root qmobile z12 pro
    By http43 in forum General Help and How To
    Last Post: 03-26-2017, 10:53 AM
  2. Why do I have a rainbow screen when charging
    Last Post: 03-06-2017, 05:21 AM
  3. How do i transfer facebook to new phone
    Last Post: 03-06-2017, 03:13 AM
  4. Replies: 1
    Last Post: 03-06-2017, 03:12 AM
  5. Replies: 1
    Last Post: 03-06-2017, 03:08 AM
