1. Janice farmer's Avatar
    I got a microsdxc uhs-i card... It is giving me "blank or no filesystem error" and unmounts the card... How can I fix it... The ops is lollipop.
    03-06-2017 04:54 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is this a brand new card? Does the phone give you any option to format it? If not, try inserting the card into your computer and see if it's readable there. If not, use the computer to format it.
    03-07-2017 02:28 AM
  1. Google syncing problem
    By Pastorhss in forum Samsung Galaxy S7 edge
    Last Post: 03-20-2017, 08:58 AM
  2. Can I upgrade my sim card to 16 gig?
    Last Post: 03-07-2017, 04:56 AM
  3. Replies: 1
    Last Post: 03-07-2017, 02:30 AM
  4. nexus 10 cdmi cable
    Last Post: 03-06-2017, 06:01 PM
  5. Cannot transfer apps to SD
    Last Post: 03-06-2017, 12:23 PM
