1. AC Question's Avatar
    I bought a phone off someone. Wounding if it's possible to user cricket servicell
    03-07-2017 07:37 PM
  2. Rukbat's Avatar
    Probably not. Cricket uses AT&T - GSM and different bands than Verizon uses (Verizon uses CDMA - totally different technology). According to my spec list, the Verizon phone doesn't have GSM capability, so it won't work on Cricket.
    03-07-2017 10:49 PM
  3. codeda's Avatar
    The newer Verizon phones do in fact have compatible bands to use on ATT and cricket but you won't get LTE. I've used the moto z droid in cricket with no issues. Might want to check the bands on the phone or If you already have a cricket SIM card would just pop it in and see what happens.
    03-08-2017 06:24 AM
  1. Replies: 1
    Last Post: 03-10-2017, 01:23 PM
  2. I can't receive phone calls while on internet
    Last Post: 03-08-2017, 03:28 AM
  3. My gmail icon is missing
    Last Post: 03-07-2017, 10:52 PM
  4. I have tried everything but my phone wont turn on!
    Last Post: 03-07-2017, 07:23 PM
  5. Replies: 0
    Last Post: 03-07-2017, 06:31 PM
