S7 Edge Always on Display custom image is way too dim, any way to fix this?
A
AC Question
So recently I've started using the AOD (Always On Display) on my Samsung Galaxy S7 Edge and selecting the Custom Image layout. However, no matter which picture I use, it always seems to come out dimmer than the actual date and time and any notifications. This is really annoying as it doesn't have a consistent look across the screen and makes the AOD look really tacky. Is there any way to fix this so that any custom inages I use are of the same brightness as everything else being shown on the AOD?
PLEASE HELP, THIS IS REALLY FRUSTRATING AS I CANNOT FIND ANY SOLUTIONS ANYWHERE ON THE INTERNET.
CrazyMoo84
Ive had the same issue for a whilr now woth the AOD brigtness.....
.....It has got to the point where it is frustrating me a lot also hence why I looked for an answer buy have yet to find a solution.
If I do become lucky & stumble across a fix then Ill be sure to let you know.
Glad Im not the onlynone having this issue though!!
Bye for now....
