1. AC Question's Avatar
    I heard that we shouldn t let our phone fully charge, only from 40% to 80%. Is that true ? ( i have the samsung note 5)
    03-12-2017 01:57 PM
  2. belodion's Avatar
    Some say yea, others nay.
    03-12-2017 02:06 PM
  3. hallux's Avatar
    That 40-80% is for long-term storage of the battery while not being used.
    We have an Ambassador's guide on the care of batteries in phones: [Guide] The Care and Feeding of Lithium Polymer Batteries
    03-12-2017 03:12 PM
  4. FatiimaAch's Avatar
    What i understood from this guide is that we should keep the battery around 30-40%. What i need to know is whether it s safe or not to fully charge the battery(100%) ?
    03-12-2017 04:34 PM
  5. belodion's Avatar
    Welcone as a new member.
    Some say yes, but others say that routinely charging to 100% shortens the overall lifespan of the battery, or that it reduces its capacity a little every time you do it.
    03-12-2017 04:53 PM
  6. hallux's Avatar
    I'm not seeing anywhere in that post that says to keep it at a charge of 30-40%. If you're going to store the battery outside the phone for an extended period of time that is correct (40-80% is optimal there) but charging to 100% should be fine.
    In all honesty, how long do you plan on keeping the device and using it? These suggestions help to keep the battery functioning optimally for 2+ years, many people are replacing their devices after 2 years.
    03-12-2017 07:28 PM
  1. Can NFC be Disabled if using Samsung Pay?
    By left4dead in forum Samsung Gear S3
    Last Post: 04-08-2017, 03:41 PM
  2. Replies: 1
    Last Post: 03-13-2017, 12:42 AM
  3. How to tranfer pictures from phone to sd card
    Last Post: 03-12-2017, 04:53 PM
  4. Why can't I send messages to my brother? On message+?
    Last Post: 03-12-2017, 04:51 PM
  5. Replies: 1
    Last Post: 03-12-2017, 03:17 PM
