1. AC Question's Avatar
    Using oneplus 3T and at night keeping everything off such as mobile data and wifi. Though it drains 2% per hour. Also using greenify to hibernate unused apps.
    03-16-2017 07:25 PM
  2. belodion's Avatar
    What do your battery usage stats indicate as using the charge?
    Mitulpadaliya likes this.
    03-16-2017 07:57 PM
  3. Mitulpadaliya's Avatar
    Battery stats...
    Attached Thumbnails I am using OnePlus 3T and my battery drains rapidly.-screenshot_20170317-080516.jpg
    belodion likes this.
    03-16-2017 09:39 PM
  4. Mitulpadaliya's Avatar
    Check the photo
    03-16-2017 10:39 PM
  5. belodion's Avatar
    All that happened overnight, between the time that you switched off mobile data, wifi, and the phone, and the time that you switched the phone on again in the morning?
    03-17-2017 04:17 AM
  1. Not all of my apps will sync
    By AC Question in forum Moto 360
    Last Post: 03-26-2017, 12:26 PM
  2. Replies: 1
    Last Post: 03-17-2017, 01:55 AM
  3. Broken/black screen and locked
    By matto2775 in forum Google Pixel & Pixel XL
    Last Post: 03-16-2017, 08:16 PM
  4. My LG G5 lock screen is just white? Help!
    By AC Question in forum LG G5
    Last Post: 03-16-2017, 07:05 PM
