1. AC Question's Avatar
    My phone with headphones on and the volume all the up it will play, but with any auxiliary cable with the volume all the way up it will not play until I turn it down
    ? I have a BLU studio xl 2, it's annoying as heck any help would be greatly appreciated.
    03-19-2017 06:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you're using an aux cable, are you saying that you have the volume on the phone turned all the way up, or on the device it's connected to? The best result when using an aux cable is to turn up the phone's vol to max, and then use the connected device's volume control for finer adjustment.
    03-20-2017 02:18 AM
  1. Will my Moto G4 Play get Nougat?
    By AC Question in forum Moto G4 Play
    Last Post: 04-06-2017, 04:36 PM
  2. Can I use my USB-C cable with normal power adapter?
    Last Post: 03-20-2017, 10:23 AM
  3. Why is my phone not ringing and always says REJECT CaLLp
    Last Post: 03-20-2017, 02:22 AM
  4. My talk to text is not working
    Last Post: 03-19-2017, 11:12 PM
  5. Will my Moto G4 Play get Nougat?
    Last Post: 03-19-2017, 05:55 PM
