1. Kingjd123's Avatar
    Please someone help me
    Thanks.
    03-20-2017 04:34 AM
  2. belodion's Avatar
    03-20-2017 06:12 AM
  3. Kingjd123's Avatar
    Yeah same problem
    today morning i unpluged my samsung grand prime plus from the charger that time battery was 100% i put my phone to pocket.after 2 hours and 23 minutes when i check battery its 87%.almost battery drain 13% in just 2 hours and 23 minutes.5.4% per hour please check screenshot and help me please
    03-20-2017 09:01 AM
  4. Golfdriver97's Avatar
    Have you done a reboot or tried a cache clear in recovery?
    03-20-2017 09:19 AM
  5. Kingjd123's Avatar
    Yeah i tried many things clear cache partition,location off,auto synch off, background data off.
    But still no good result..
    Thanks for your reply..
    03-20-2017 09:33 AM
  1. How do I open file on my home screen?
    Last Post: 03-20-2017, 03:26 PM
  2. Replies: 1
    Last Post: 03-20-2017, 10:44 AM
  3. where is the home key located at on my Galaxy note 5
    Last Post: 03-20-2017, 03:23 AM
  4. samsung battert drain when not in use
    By Kingjd123 in forum Ask a Question
    Last Post: 03-20-2017, 02:34 AM
