1. AC Question's Avatar
    The problem is my 32gb microSD card will not be recognized by anything. By anything I mean cameras, portable DVD players, computers, audio recorders. Everything. The card was working fine and I use it with an adapter to watch videos and listen to music on a portable dvd player. I leave it plugged in the usb slot when the player is not in use. I turned it on a few days ago and the player could not read the card. I then plugged the microsd card into a computer and it registered that something is plugged into the specific usb slot but that nothing is there! When I plug it into the computer the computer will become sluggish when I try to open properties on the card and when it does open is says 0 for space used and space available. When I try to format the card, the computer says that the card only has 121 mbs of space on it in the format box and then the format is unable to complete. No program will read the card and when I try to update the drivers with the card plugged in the computer will not even open the drivers management section in computer! What can I do? Is my card gone forever? There is nothing physically wrong with it. It looks the same as when I bought it 6 months ago. Now it just wont read. What can I do?
    03-23-2017 07:37 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The card is likely corrupted and unrecoverable. SD cards do not last forever, and can fail unexpectedly, which is why you should never rely on them as the only place to keep important data.
    See if chkdsk can scan the card and fix any bad sectors: [GUIDE] Using chkdsk to fix a corrupted SD card
    03-23-2017 11:08 PM
  1. How can I watch my video (moto G4) ?
    Last Post: 03-24-2017, 02:26 AM
  2. how can i get my lost camera app on lava iris x 8?
    Last Post: 03-24-2017, 02:07 AM
  3. why my phone restart ?
    Last Post: 03-23-2017, 11:32 AM
  4. will galaxy s7 case fit a s4 phone
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-23-2017, 08:36 AM
  5. my moto e3 is heating very much
    Last Post: 03-23-2017, 08:32 AM
