1. AC Question's Avatar
    I have major problems with the settings of my S6 edge, after updating to nougat last week:
    Emergency message can't be activated
    Sound settings keep changing by themselves, volume level randomly increases
    Don't disturb mode shows on but is actually not
    After non working don't disturb mode switches off at set time, all volumes are on highest level
    I don't always get Whatsapp message alerts, about 75% of the messages I only get when opening the app (app alert is on)
    Tbc
    Anyone there who can help?
    Thanks!!!
    Phiphi2001
    03-25-2017 04:35 PM
  2. matias20r0877's Avatar
    Yes , i also noticed that Nougat 7.0 is very unstable , because it was just released and it may still be in development.
    So i suggest installing a custom ROM from XDA .
    The ROM is called Helios 7.9.0
    It is pretty much the best ROM i ve tested ..and i have tested many ROMS.
    Plus , the ROM is much more stable and you will get no problems
    03-25-2017 06:38 PM
  1. Replies: 2
    Last Post: 04-18-2017, 10:10 AM
  2. why no V20 security updates
    By huungryshark in forum LG V20
    Last Post: 03-28-2017, 03:40 PM
  3. Replies: 1
    Last Post: 03-26-2017, 04:40 PM
  4. Anyone in the UK had the Google Assistant update yet?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-26-2017, 04:23 PM
  5. Anyone in the UK had the Google Assistant update yet?
    Last Post: 03-25-2017, 03:43 PM
