1. AC Question's Avatar
    how do I know if I have inserted the SD card or the chip the correct way? They fell out as I removed the compartment they sit in and I am not sure I put them in the right way.
    03-26-2017 04:03 PM
  2. belodion's Avatar
    I think they're designed so that they only go in the right way.
    03-26-2017 04:09 PM
  3. SactoKingsFan's Avatar
    Depends on the phone. Some have a slot that you put the card in. Others have a microSD and SIM card tray. There's only one way it can go in. What phone do you have?
    03-26-2017 04:13 PM
  1. Replies: 5
    Last Post: 04-09-2017, 11:27 PM
  2. Replies: 5
    Last Post: 03-27-2017, 05:25 PM
  3. What is 10053 in battery useage
    By streetkilln in forum Moto Z Play & Z Play Droid Edition
    Last Post: 03-27-2017, 02:59 AM
  4. What is the best Antivirus for google play?
    By tonyafoxworth in forum Ask a Question
    Last Post: 03-26-2017, 05:37 PM
  5. How do I get the widget on my S6 lock screen
    Last Post: 03-26-2017, 04:11 PM
