1. AC Question's Avatar
    My phone has been freezing and then getting into reset loops that I can't fix. I have read the forums here and have tried all of the fixes that I have read. I have done recovery booting, wiped cache partition, done a factory reset and it still gets in the reset loops. I have booted in safe mode and it still crashes and then gets in the reset loop.
    I am at a complete loss. Hoping someone can help
    03-26-2017 07:23 PM
  2. SpookDroid's Avatar
    Do you have an SD Card inserted? If so, try removing it, turn the phone off, turn it back on, re-insert SD card.
    Also, do you have any 'sideloaded' apps or manually installed? Some of those might cause bootloops if they aren't compatible or don't have the appropriate license.
    03-26-2017 08:28 PM
  3. svennyi's Avatar
    I don't have any sideloaded apps. I do have a SD card. I followed your instructions, but I am still in the reset loop.
    03-26-2017 09:06 PM
  4. SpookDroid's Avatar
    what about removing the SD card completely. Does that help?
    03-27-2017 02:05 AM
  5. svennyi's Avatar
    It eventually stopped and I haven't had the problem for about 36 hours, so hopefully that worked. Thank you for your help
    03-28-2017 02:58 PM
  1. Proxy problem on some websites when on 4G (Samsung S6)
    Last Post: 03-27-2017, 05:20 PM
  2. Samsung cloud good to use?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-27-2017, 12:53 AM
  3. How can I get my samsung j3 emerge sprint unlock code
    Last Post: 03-26-2017, 06:59 PM
  4. Why is Ramadan in my calender?
    Last Post: 03-26-2017, 06:45 PM
  5. Samsung cloud good to use?
    Last Post: 03-26-2017, 05:49 PM
