1. Rikku Watro's Avatar
    My LG X power keyboard just keeps having two problems: lagging and caps lock problems. The lag happens when I press any key on the keyboard (sometimes causing a typed word to disappear when I type fast), and the caps lock occasionally turns itself on even when autocorrect and auto-capitalization are both disabled. The keyboard also turns Shift back on if I type a word beginning with a capital letter and erase it. Please help!
    03-30-2017 04:05 PM
  2. X1tymez's Avatar
    Can you try reset keyboard data and cache in setting/App.
    03-30-2017 04:10 PM
  1. Strange calandar sync problem
    By Pastorhss in forum Samsung Galaxy S7 edge
    Last Post: 03-31-2017, 02:01 PM
  2. I can't make up my mind! Help!!
    By JJSooner in forum Ask a Question
    Last Post: 03-30-2017, 05:04 PM
  3. Replies: 1
    Last Post: 03-30-2017, 04:52 PM
  4. Galaxy S7 Edge: Just Updated To Nougat!! Multiple wallpaper help!
    By MoonMakeup in forum Android 7.0 Nougat
    Last Post: 03-30-2017, 01:00 PM
