1. AC Question's Avatar
    i recently bought the s7 edge, put in a 128gb... and later all photos on my sd card appeared as !.
    i later bought a new sd card and it has completely vansish from my fone, i can not open the SD card on the fone. it will not read.
    on the computer it showed error then now wont read.
    04-05-2017 09:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The SD card could be corrupt, defective, or counterfeit. Install SD Insight to see if the card is genuine or counterfeit. Counterfeit cards are programmed to report more storage than they actually have, and if you try saving more than the card can actually hold, then files can start getting corrupt.
    If it's a valid card, then go to Settings>Storage, Unmount the card, remove it, and insert it into your computer. Can the computer read these files? Backup as much as you can right now, then run chkdsk to look for bad sectors: [GUIDE] Using chkdsk to fix a corrupted SD card.
    04-05-2017 10:22 AM
  1. Risk of burning image on display with AOD?
    By jus2sho in forum LG G6
    Last Post: 04-08-2017, 12:55 PM
  2. My sim card is detected but i cannot call or send message
    By Abhishek 11 in forum Xiaomi Android Phones
    Last Post: 04-05-2017, 10:27 AM
  3. Why is thre no automatic time zone for samsung galaxy tab3V
  4. How do i activate the notification light on my moto g5
    Last Post: 04-05-2017, 10:26 AM
  5. Replies: 0
    Last Post: 04-05-2017, 08:36 AM
