1. AC Question's Avatar
    no audio when i try to use my head phones. I have already tried 3 sets of head phones and 3 different dongles. If I start playing music with out the headphones plugged in there is no problem but when I plug the headphones there is no audio, iI have tried it other ways (start with head phones plugged in ...etc). I have tried different apps and google play. Also when I plug the phone into my PC it will only charge and doesnt bring up the usb connection option (yes already enabled debugging and set to ptp) Pretty sure its a software issue but this is also my second phone doing the same thing. Couldbe another bad phone but thats not as likely. Anyone have any other ideas?
    04-07-2017 07:43 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. In android 6.0 and above, when you plug your device into a PC, you need to open the device, and pull the notification shade down. You will see a notification for charging. Tap that and you will get a list of options, file transfers being one of them. Tap that, and you can transfer files to your PC. This option sticks as long as the device is plugged into the PC. Once you unplug it, you will have to do those steps over again when you plug the device back in.
    04-07-2017 08:49 AM
  3. egwiaz's Avatar
    yeah thats the way its supposed to happen but when I do the pull down and tap the charging notification it doesnt give me the option for file transfer..... it actually doesnt even give me that notification for charging either I have to press the battery symbol and that will take me into the charging screen
    04-07-2017 09:50 AM
  4. Golfdriver97's Avatar
    What device do you have?
    04-07-2017 02:12 PM
  5. egwiaz's Avatar
    Droid moto Z
    04-07-2017 07:35 PM
  6. Golfdriver97's Avatar
    Have you tried a reboot?
    04-07-2017 07:56 PM
  7. egwiaz's Avatar
    reboot and factory reset and of course a new phone. Tried to connect phone to multiple pc's
    04-07-2017 08:04 PM
  8. Golfdriver97's Avatar
    I'm honestly at a loss. Have you tried calling Motorola?
    04-08-2017 02:05 PM
  1. Replies: 5
    Last Post: 04-10-2017, 04:51 PM
  2. Replies: 1
    Last Post: 04-07-2017, 08:29 AM
  3. Phone not curernCannotCannot connect callsCannot make calls
    Last Post: 04-07-2017, 07:08 AM
  4. Replies: 0
    Last Post: 04-07-2017, 07:06 AM
  5. Why does my phone hangup after 2 hours of conversation?
    By Jennifer554 in forum Ask a Question
    Last Post: 04-07-2017, 06:47 AM
