1. AC Question's Avatar
    My original cord got damaged, so I'm trying to find an adequate replacement. One that would put out enough power to charge it with the specifications it requires.
    04-09-2017 01:22 AM
  2. X1tymez's Avatar
    You can look at old cord label. They should display the correct amp.
    04-09-2017 01:34 AM
  3. Rukbat's Avatar
    If the charger can't put out as much current as the phone requires, but it puts out more current than the phone is using, all that will happen is that reaching a full charge from any given point will take longer. Unless it's a 10 year old charger, using a charger that's a bit too small won't hurt anything.
    04-09-2017 03:15 AM
  1. Why won't my apps transfer??
    Last Post: 04-09-2017, 09:05 AM
  2. WHY WONT MY PHONE MAKE OUT GOING CALLS? It
    Last Post: 04-09-2017, 03:02 AM
  3. Data in sd card changes into weird files.what to do?
    Last Post: 04-09-2017, 03:00 AM
  4. My camera is not working.. it says
    Last Post: 04-09-2017, 01:43 AM
  5. How to find stolen note5 that doesn't have a find me app
    Last Post: 04-09-2017, 01:12 AM
