I've been trying for some time now to map the jump key for my MOGA Pro Power gamepad for the Xash3D FWGS engine port. I'm trying to do this for Half-Life, but neither the in game mapping tool, nor the config file seem to be working. So far it's been pointless to use a gamepad without the ability to jump, I can't even progress past the tutorial. I've tried numerous button variables, but to no avail. I want to map the A button to this function. I should also note that there is nothing wrong with the controller, as games that support it natively work fine. What's even stranger is that the A button, as well as start and select aren't detected either, but all other buttons are by the in-game config. The internal strings for the key binds within the controller's firmware are as follows:
button_Y
button_X
button_B
button_A
GAS_R
GAS_L
ect...
I would think that manually using the button_A bind for jump would work, even if the engine isn't registering the button in-game, but it still doesn't register. Are there other "A button" binds that I could use? Does anyone know how to fix this?
button_Y
button_X
button_B
button_A
GAS_R
GAS_L
ect...
