1. AC Question's Avatar
    I have a Galaxy Note 5 with a Mophie juice pack which serves as its protective case. I'm kind of sick of the mini-USB slots getting loose and the mini-USB cables not fitting. So I'd like to try wireless charging, WHILE THE MOPHIE IS ON. But has anyone tried it and gotten it to work?
    I know it works on some other phones and some other cases, even some Mophies. I contact the Mophie people to ask. Their customer support basically said "I donno" and shrugged their electronic shoulders. They said it may work, it may not, you'll just have to try it. Which trial will cost me something around $100.
    So if you've tried it and can tell me the results I'd appreciate it.
    05-17-2017 08:10 PM
  2. Tim1954's Avatar
    I'd go into a shop selling the wireless chargers and tell the assistant I want to try the set up. If it works, I'll buy the unit.
    05-17-2017 11:11 PM
  1. Are you still happy with your G6?
    By Jeremiah Bonds in forum LG G6
    Last Post: 05-23-2017, 12:03 PM
  2. Replies: 5
    Last Post: 05-21-2017, 07:05 PM
  3. TMO to introduce its own phone?
    By raino in forum T-Mobile
    Last Post: 05-18-2017, 06:25 AM
  4. Replies: 0
    Last Post: 05-17-2017, 06:11 PM
  5. Replies: 1
    Last Post: 05-17-2017, 05:51 PM
