1. Indranil Jana's Avatar
    Dear sir, I newly buy a Asus memo pad me 172 v tablet and as connected my Kingston 8gb pen drive through OTG cable my tablet suddenly goes shut down with showing Message battery low.it happen several time when I read a PDF book or watch a video. Why it happen? Does the micro USB slot not compatible with pen drive? Then what the use of otg cable? Plz help me . Why this problem?
    05-09-2013 06:58 AM
  2. asus_usa's Avatar
    Is the battery fully charged? If it is showing a "battery low" message, then the first thing I would check is the charge on the tablet. The ME172 is compatible with an OTG cable and flash drives.
    05-09-2013 06:10 PM
  3. Indranil Jana's Avatar
    Yes sir it fully charged. And the tablet behave only the time of using pen drive thru otg cable which come with tablet. And its happen not only all time but also some time on a day.suppose in the morning I turn on tablet and connected pen drive and read PDF book stored in pen drive after few minutes suddenly tab goes shut down with show battery low it happen only pen drive using time and I also checked another pen drives but it same problem . I update firmware and full faetory rest but problem is same.pls help how it fixed. What the problem in it? Should I go Asus India service center?
    05-09-2013 10:33 PM
  4. asus_usa's Avatar
    If you haven't already, please call this number: 1800-2090365. That is the support number for India. They will be able to direct you to the nearest service location that can look at your tablet. If no location is close by, they might be able to arrange mail-in service for you.
    05-15-2013 05:06 PM
  5. Joshua Jabakumar's Avatar
    Yeah, just safely eject your pen drive by pressing the eject button. This eject button along with the drive name appears in the "notification area and settings" which is usually at the top most area showing time and battery level.
    10-12-2013 12:42 AM
  1. Asus MeMo Pad Gets Android 4.2 Jelly Bean Update
    By gorwani12 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-16-2013, 10:22 AM
  2. Is The Asus MeMO Pad 7" Good For Reading
    By KiritoS in forum General News & Discussion
    Last Post: 04-09-2013, 11:25 AM
  3. USB problems with Froyo
    By retrev in forum Verizon Fascinate
    Last Post: 10-12-2012, 08:19 PM
  4. recommend me a spare micro usb cable
    By DroidBehavior in forum AT&T Galaxy S II
    Last Post: 10-28-2011, 12:43 PM
  5. Wtb: Rocketfish micro usb charger with serial code rf-mcb90
    By Matty-Mo in forum Marketplace Archive
    Last Post: 02-10-2011, 11:42 PM
