Re: Battery/Charging Issue
Interesting issue. I found that after my JB upgrade it took a while for things to settle out. I would check batter, under setting and look to see whats eating your battery.
Rick
Sent from my Transformer Prime TF201 using Android Central Forums
You mean while the Prime is in the Dock and plugged into the wall it wont charge? Or when it's not plugged into the wall, but, in the dock, power doesn't transfer from the dock to the Prime?
There is an app called Asus Keyboard. You can try clearing cache/data on that. I don't think it's on onscreen keyboard because there is another app called Android Keyboard.
When I updated, I noticed that a lot of my settings had changed after noticing some weird incidents during my daily use. So I echo the above post...check your settings and also keep an eye out as the upgrade "settles".
