Results 1 to 4 of 4
    Korpellas Kitchen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery/Charging Issue
    I am new to this forum, and forums in general for that matter. I recently upgrated to JB. And recently also let the battery go to zero, by accident. Now my TF201 does not charge while on the keyboard dock, even after 70% power. I have tried cold booting, and doing a factory reset. Help!!
  2. #2
    frsimpson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery/Charging Issue
    Interesting issue. I found that after my JB upgrade it took a while for things to settle out. I would check batter, under setting and look to see whats eating your battery.
    Rick
    Sent from my Transformer Prime TF201 using Android Central Forums
  3. #3
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/Stock/CM9
    You mean while the Prime is in the Dock and plugged into the wall it wont charge? Or when it's not plugged into the wall, but, in the dock, power doesn't transfer from the dock to the Prime?
    There is an app called Asus Keyboard. You can try clearing cache/data on that. I don't think it's on onscreen keyboard because there is another app called Android Keyboard.
  4. #4
    enthuz's Avatar
    Posts
    Global Posts
    1,021 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I updated, I noticed that a lot of my settings had changed after noticing some weird incidents during my daily use. So I echo the above post...check your settings and also keep an eye out as the upgrade "settles".
  1. Weird battery charging issues
    By Moo Cow in forum Samsung Stratosphere
    Last Post: 10-22-2013, 01:51 PM
  2. epic touch 4g battery/charging issue
    By maynardjk13 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 02-22-2013, 06:46 PM
  3. Strange Rezound battery charge issue
    By Ed Witles in forum Verizon HTC Thunderbolt
    Last Post: 12-31-2011, 06:28 PM
  4. Battery/Charging issue
    By anon36845 in forum Motorola Xoom
    Last Post: 06-08-2011, 01:46 AM
  5. Battery charging issue after 2.2...who to notify?
    By Chondog in forum Verizon Droid Incredible
    Last Post: 09-08-2010, 02:00 PM
