OK - I am very educated on Battery Problems. Here is my question/problem. I use the Airplane Mode (the one by DON) and I have the dual battery widget.
I get only a 1% drop all night when there is a charge in the dock above say 7%. If the dock is 3% or less, and the Pad is at 100%, then the drain becomes rapid. Almost as if the dock is trying to gain power from the Pad. I put it to sleep - auto airplane mode, use Astro Files to kill all apps/services, etc..., and the drain can be 30% overnight when docked. When it is NOT docked - the drain returns to normal. Has anyone solved how to keep it docked, have the dock be not charged, and have the battery life not deplete rapidly in sleep mode?
Hope that makes sense!
