Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By shoooter
  • 1 Post By Sizzers
  • 1 Post By bambulko
    Default switch on problem
    Every time i switch on my FonePad,it automatically show the tutorial(how to create folder,drag apps...)
    Then when i delete the homepages,but it will return to 5 pages every time i switch it on.
    I dont know what is the problem of it n it still showing tis every time when i switch on.
    Its really frustrated!
    Hoping anyone can help me..
    Thx a lot.
  2. #2
    Default Re: switch on problem
    Me too:-)
    Envoy de mon K00E en utilisant Tapatalk
    Derren Chong likes this.
    Ur FonePad become like this after update?
  4. #4
    Sizzers's Avatar
    Posts
    Global Posts
    549 Global Posts
    I would suggest going in to Settings>Apps>All and look for anything which says "Guide, Tutorial, Demo...etc" and disable it.
    These things usually can be disabled and without effecting any other apps. Obviously if you start experiencing any strange behaviours then re-enable it to see if that may have been the cause but I would't expect any such problems.
    It doesn't works.It doesn't hv the running "tutorial apps" in the list.
    Anyway, tq.
    Is thr any solution?
    Is thr any other solution u know??
    - - - Updated - - -
    Quote Originally Posted by shoooter View Post
    Me too:-)
  8. #8
    Rooting is the only solution, but we don't have a successful method for rooting, we wait
  9. #9
    Have you tried a different launcher?
    Sizzers likes this.
  10. Thread Author  Thread Author    #10
    not yet,wat launcher do u suggest??
  11. #11
    I use APEX
  1. GO SMS PRO problems
    By mvp4him3 in forum Droid RAZR MAXX
    Last Post: 03-22-2015, 01:05 AM
  2. SD card problems
    By revjong in forum LG G Pad 8.3
    Last Post: 11-10-2014, 12:00 AM
  3. Touch screen problem, grounding
    By dajobo in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-24-2014, 10:31 PM
  4. Android/Google Play Market Place Problems
    By Piita kun in forum Motorola Droid X2
    Last Post: 01-03-2014, 11:38 AM
  5. strange notification on Sgs3 security update siver shield looks odd?
    By silversjf in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-01-2014, 08:01 PM
