1. pmlabrier's Avatar
    There are numerous apps that will turn any case into a smart case using the proximity sensor of a fonepad.
    I am currently am trying the demo version of Smart Screen Off. Liking it fairly well
    Paul
    Sent from my ME371MG using AC Forums mobile app
    06-27-2013 08:39 PM
  2. Methos2010's Avatar
    Just downloaded Smart Screen lite. Thank you.
    08-04-2013 10:17 PM
  3. kinged33's Avatar
    I just tried smart Screen off. It appears to be a disaster. When I touch the screen to do something, the screen turn itself off and then back on. I opened the pattern security lock, the same thing happens again. I quickly uninstalled.
    08-10-2013 03:40 PM
  4. Methos2010's Avatar
    Is it possible that you were covering the proximity sensor? I actually turn it off when I am using teh pad for long periods of time, but it saves me the hassle of turning teh fonepad on and off, which I find inconvenient.
    Hope that helps!
    08-14-2013 01:18 AM
  1. MOD-CASE for galaxy S3
    By MODCASE in forum Samsung Galaxy S III Accessories
    Last Post: 09-24-2014, 04:53 AM
  2. What would you like to see on the next version of SHIELD?
    By Kevin O'Quinn in forum NVIDIA Shield Portable
    Last Post: 07-04-2013, 06:37 AM
  3. Using the Xperia Z as a "tablet"
    By grommmm in forum Sony Xperia Z
    Last Post: 06-28-2013, 02:15 PM
  4. Replies: 5
  5. Best site to look up S4 / Android Alternative Apps
    By CountryDude in forum Samsung Galaxy S4
    Last Post: 06-27-2013, 06:11 PM
