Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By flyhighx
    Default Does the keyboard charge the tablet or how does the battery work?
    I just want to be clear on something... when I connect my keyboard to my tablet, does the keyboard then charge the tablet while I'm using it? Two both batteries drain simultaneously? Or am I using the keyboard's battery first? Just not clear on this one.
    Thanks!
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  2. #2
    Default Re: Does the keyboard charge the tablet or how does the battery work?
    The keyboard will acutally charge the tablet. Don't quote me on the specific numbers but the keyboard will let the tablet battery drain to 70% and then start to charge the tablet. If the tablet is already below 70%, charging will start immediately. I guess this is done so there is not a constant drain. It actually works out exceptionally well. If you start with two fully charged units and keep them connected, the keyboard will drain first, leaving you with a fully charged tablet to continue on with. If your tablet is low on battery, instead of plugging it into it's charger, you can click it into the keyboard. I've found this to be especially usefull while on the road.
    c00l0ne and NothingIsTrue like this.
  3. #3
    Red face Re: Does the keyboard charge the tablet or how does the battery work?
    I wanna ask... When my dock battery is 0%, does it do anything to tablet's battery? I mean, if I charge the tablet too often, the battery is gonna be worse... so is it safe when the dock is 0%?
    Thanks!
  4. #4
    berndlb's Avatar
    Posts
    ROM
    CleanROM Inheritance 3.3
    Quote Originally Posted by Bony chan View Post
    Thanks!
    The answer is no, it won't do any harm to your battery. Also, the days when batteries would not take a full charge if you didn't completely drain them, are over. Used to be that way, but thankfully technology improved.
    Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
  5. #5
    I've found that my tablet can get down to about 75%, and if it's docked in the keyboard and the keyboard still has some charge left, then the keyboard will start to charge the tablet. I usually dock the tablet overnight and if I see that the keyboard is low, I'll charge it separately, but I normally find that they drain down pretty well together, and I usually charge them together, i.e. turn off the tablet after I connect the tablet to the keyboard and connect the charger to the keyboard, so they charge at the same time.
  1. Replies: 2
    Last Post: 03-08-2011, 08:24 AM
  2. how does the epic keyboard compare to the moment
    By stickywhipit#ac in forum Sprint Epic 4G
    Last Post: 08-31-2010, 12:53 PM
  3. How does the Evo wake up from stand by?
    By Josh K in forum HTC EVO 4G
    Last Post: 05-28-2010, 11:50 AM
  4. Replies: 2
    Last Post: 05-03-2010, 04:35 PM
  5. How does the OS handle running apps...
    By qdroid in forum Verizon Droid Incredible
    Last Post: 04-30-2010, 03:41 PM
