Guys - do this. Im no Tech - savvy guy but i did this, and it improved at least 20%. EXCEPT for the Camera part - Zenfone 2's camera is a battery Juice SUCKER
note : used camera for 5 mins and battery down 15% !!!
a)
AUTO -START MANAGER - to stop unnecessary apps from strating by themselves upon STARTUP
b)
Google Search (Google Settings) - Stop all auto-synch. We can still synch as and when we want to.
c) Some apps can't be disabled - OPEN ALL apps that include those which can't be disabled.
Go to
POWER SAVER - Then click the 3 dots (top right hand corner) - click BATTERY
Again, click the 3 dots above --> select APPS POWER USAGE DETAILS
U will find a list of apps using the battery - click on the apps that you DO NOT WANT to wake up 'forever'
Just tick on the 2 boxes for EACH individual app (pls do it manually for each and every app) - including those unused (but can't be disabled)
Then RESTART the Zenfone 2
d)
WIFI - long press the WiFi icon and you will find 3 dots on the top right hand side again. Click on it, select ADVANCED ---> Off both NOTIFY WHENEVER A PUBLIC NETWORK IS AVAILABLE & SCANNING ALWAYS AVAILABLE ( These 2 are the MOST battery draining wifi prob, i guess)
Next, pls select the Wi-Fi frequency band as apposed to AUTO
e) Off the phone and do a
WIPE CACHE PARTITION. As apend below :-
Wiping partition cache will resolve any conflicts caused by residual cache from the earlier firmware version
1. Switch off the phone by pressing the power button. It will show menu option to turn power off.
2. Press and hold power + volume up button . After it buzzes/vibrates RELEASE POWER BUTTON only.
When Asus Logo appears - RELEASE VOLUME UP button
3. It will boot into bootloader mode. You will get option to select Recovery mode by using the Volume rockers. Select it by using the power button.
4. Then the phone will reboot and show error written with Android icon lying belly up. When you see that press and hold power button and press and release volume up button.
5. It will enter the recovery mode successfully and show several options.
6. You will get option to wipe partition cache. Use the volume rockers to move to that option.Select it by pressing the power button.It may take 10 mins to wipe it fully.
7. It will come back to the menu . Select reboot after that.
I hope it helps. Sorry if im not tech-savvy enough to clarify better in Tech terms.
CHEERS
