Results 1 to 6 of 6
- 01-22-2012, 04:25 PM
Thread Author #1
Pleassse help me and read this :(
heloo guys i come at u in a very depressed almost gaven up state. i recently purchased a motorola atrix it came with the latest firmware and software on it so i decided to root it then i decided to unlock the bootloader so i can install roms from sd card. i downloaded cynogen mod 7 because it looked awesome. i i rebooted it and let super user take control. it went to the skating android guy bootlogo and now it wont do anythingelse. it wont boot into os. i have tried everything from deleting all user data to doing factory reset from recovery menu and everything in between i even tried using the automatic unlock no os boot fix. it just stays on the basic android boot screen. i plug it into wall charger and it comes on. if i unplug it the phone will immediatly go off, i even took the battery out of the device and plugged it in and it still turned on.. with no frikin battery. it wont charge on wall caus eeverytime i unplug it it goes off. i plugged it into pc and a green light comes on but its not regognized by pc. the main thing im trying to do is get the phone charged up enough so that i can go into fastboot protacol support so that it can be flashed with rsd light and a firmware file that will dowengrade it. it says the battery is to low to flash so i cant use rsd light. i need to find a way to make the phone charge so i can flash it.. please im beging u. please help me find a salution. i relly want to be able to flash it so it can work again. thanx for any and all replies and i will find some way to repay the person who helped me... - 01-22-2012, 05:40 PM #2
Re: Pleassse help me and read this :(
Replace your battery
- 01-25-2012, 08:56 AM #3
- 02-10-2012, 07:16 PM #4
- 02-11-2012, 12:22 PM #5
- 02-11-2012, 12:26 PM #6
If i were you i would flash the stock SBF with RSD lite and bring it back to stock.
You will more than likely get stuck in a bootloop after this but dont worry. All you need to do is go into the stock android recovery do a factory data reset and clear dalvic cache and your device should boot back up.
I say this from experience because the same thing happened to me. Good luck.
Reply
