Skype and Battery questions
wallabob
3
Hi, I'm new to this fourm so im not really sure if I'm able to post in here...
But anyways I have trouble w/ skype...I can make calls but theres not video. Also the battery takes a very long time to charge, its pretty anonnying.
Thanks for reading, any input would be nice :D
souja67
22
There is no video calls for skype right now on android. Hopefully soon though. I have also noticed that it takes forever to charge. Not sure why that is.
hellosailor
154
5
Typical USB charger puts out only 500mA, which is the rated max for a USB port on a computer as well.
Motorola Atrix charger puts out 850mA because the battery needs a high power charger. Some Moto chargers put out over 1000mA.
All you can do is use a correct high-power rated charger, or buy a second battery and just swap them out if you need a fast "charge".
You'd think Skype would be in a hurry to provide video calls on cell phones. Nope. Bug them for that!
ThatDude
