DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 5 of 5
    Unhappy Nook Color - wireless has completely quit
    My rooted Nook running CM7 (07222011 nightly) no longer sees any wireless networks. It worked for a while after installing the update. I have Wifi analyzer installed and it just shows nothing.
    I've tried rebooting, enabling and disabling wireless repeatedly, turning Airplane mode on and off. It doesn't see my network from anywhere in my house, even right next to the router, nor any of my neighbors' networks that it normally sees.
    I just fired up inSSIDer on a laptop and it sees the networks that I'd expect to see. Any ideas?
    Thanks.
  2. #2
    kcls's Avatar
    Posts
    ROM
    IHOCM7.2 || AOKP
    Default Re: Nook Color - wireless has completely quit
    Nightlies are only test builds, any one of them could have something wrong with them. Something could be working in one release, but the next one, it may stop working. I would suggest switching to CM7 RC1. I have been using it for a couple of weeks and it works fine.
    Thanked by:
    Andy_S
  3. #3
    Try the latest RC, if you still don't have wifi try going back to stock and seeing if it will work from there.
    Thanked by:
    Andy_S
    You guys were right. I rolled back to the latest RC, and it's working again. Strange that it worked fine for a couple of days on that nightly.
    Thanks!
  5. #5
    ioo
    ioo is offline
    ioo's Avatar
    Posts
    ROM
    Stock
    The nightlies are currently having various issues with wifi. Keep an eye on the CM7 forums. They will work it out eventually.
