Results 1 to 2 of 2
- 08-31-2011, 11:02 AM
Thread Author #1
need help
i had nook color with CM7 Running off SD card, i need to take out android to sell the nook.
I removed the SD card thinking that was the only thing needed to do. Now my nook wont charge.. stuck on low battery screen wait 15 minutes.
Do i need to un mount the sd card or something? or should it work right off the bat as stock?
thanks - 08-31-2011, 04:36 PM #2
You might have accidentally flashed something when first setting up your SD card.
Check out this thread on how to return to stock. [HOW-TO] : Restore Nook Color back to stock EASILY! UPDATE:1/3/11
Sent from my LG Optimus V using Tapatalk
Reply
