Results 1 to 3 of 3
    popeye's Avatar
    Posts
    Global Posts
    277 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default CM7-Does Not Connect To Wifi?
    Things working fine. Now I can not connect to Wifi. I unchecked and checked Wifi. It turns on but does not connect. Says connecting and then says disconnected?
    Any ideas/solutions?
    Thanks.
  2. #2
    koopakid08's Avatar
    Posts
    Global Posts
    953 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Delete all remembered networks and then reboot.
    Sent from my LG Optimus V using Tapatalk
    shaunm44 likes this.
    popeye's Avatar
    Posts
    Global Posts
    277 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: CM7-Does Not Connect To Wifi?
    Perfect again. Looks like one of the saved blocked it. Works fine.
    Thanks again
