1. aviduser's Avatar
    I can get it into Clockwork Recovery by holding the N button and power button till it boots. I have tried installing and reinstalling 7.1. I have tried wiping and reinstalling 7.1. Everytime I reboot, it shows the splash screen and freezes on a blank black screen.
    Any ideas?
    BTW, I am not all that experienced with rooting/flashing, etc.
    Thanks,
    aviduser
    12-13-2011 09:00 PM
  2. koopakid08's Avatar
    A few questions:
    What is the version of clockwork you are using?
    What were you doing before this happened?
    Have you tried restoring to stock?
    Sent from my LG Optimus V using Tapatalk
    12-13-2011 11:04 PM
  3. aviduser's Avatar
    A few questions:
    What is the version of clockwork you are using? LATEST VERSION (PRETTY SURE)
    What were you doing before this happened? WAS HAVING THE SLEEP OF DEATH ISSUE (BEFORE I KNEW IT WAS A THING), SO I TRIED REINSTALLING CM 7.1 UPDATE
    Have you tried restoring to stock? YES, I HAVE TRIED WIPING AND RESTORING--IS THERE ANOTHER WAY TO GET TO STOCK?
    Thanks for your help. My device is basically bricked, except that I can get it into Clockwork.
    aviduser
    12-14-2011 02:31 PM
  4. digitalslacker's Avatar
    Nook Color's are hard to brick. They have Boot SD card priority and if you are getting into CWM then it's fixable.
    here's the easiest way to get to stock.
    [HOW-TO] : Restore Nook Color back to stock EASILY! - xda-developers
    good luck!
    12-14-2011 03:29 PM
