1. kmpham1's Avatar
    Hi,
    I recently rooted my Nook Color and have cm7.1.0 on it. I did research and found out that this version of cm7 has the ability to overclock built in. I have found the CPU settings under CyanogenMod settings, but I am not sure what CPU settings to punch in. I currently have on demand governor, min cpu of 300mhz, max cpu of 1100mhz, and set on boot checked. The speed difference is not very noticeable to me, so did I do something wrong? Should I change the governor, min cpu, or max cpu?
    Thanks for all your help, I really appreciate it!
    08-08-2012 12:27 PM
  2. climoman's Avatar
    Nope, you have it set right. I use the SetCpu app and mine is able to overclock higher, however, many threads state set no higher than 1200(1.2Ghz) due to instability issues.
    08-21-2012 09:56 PM
  3. koopakid08's Avatar
    Try an interactiveX governor
    Sent from my HTC Evo V 4G
    08-24-2012 07:10 PM
  4. Pre-dawn raid's Avatar
    Mine is running well on 1200mhz with the performance governor. Helps smooth out gameplay on more demanding games like Oscura for example.
    Sent from my NookColor using Android Central Forums
    12-08-2012 08:10 PM
