Results 1 to 5 of 5
    Default Firmware 1.1.0 pri/rooted breaks ADB
    Apologies if this has been posted or if in the wrong section.
    I recently as of 2 weeks maybe updated my NC to the flashable Nook firmware update 1.1.0 that is pre-rooted. Just noticed yesterday that I no longer can access my nook via adb. When I connect usb and issue the adb devices....Nothin. So I booted the NC to Nookie Froyo SD and tried my installation of ADB again and had no problem. Can connect mount,umount, shell everything.
    So what gives? Am I missing something? Is there an update to the ADB environment?
    Help appreciated.
  2. #2
    Biffer's Avatar
    Posts
    Global Posts
    53 Global Posts
    ROM
    CM7
    Default
    No help here, but I have the same issue.
  3. #3
    Default
    This is a known issue with the pre-rooted update. Go into Nook Color Tools>all settings>development and deselect and reselect USB debugging and ADB will work. It will also quit working when you disconnect and reconnect and you will have to redo it again. I hear that ADB Wireless still works fine.
  4. #4
    Biffer's Avatar
    Posts
    Global Posts
    53 Global Posts
    ROM
    CM7
    Default
    Quote Originally Posted by Ramdriver View Post
    I saw that suggestion over at XDA, but it did not work for me in rooted 1.1. I installed Nookie Froyo to my eMMC today, and have no issues accessing the NC with ADB.
  5. #5
    Default
    I downloaded adbWireless from the Market and it works perfectly. You can adb into the device through your wifi connection.
